Real wood flooring on Concrete floor??
25 Nov 2006
Hampshire
Hello!
Advice needed: I'd like a real oak floor but have a concrete floor, does anyone know if this is possible (no height for laying ply (?) first). Is there a new type of solid wood flooring that can be laid straight onto concrete? Is engineered board any good?
Any help greatly received.
What is the thickness of your solid boards? Are they T&G'ed?
Normally not a problem to install solid boards floating on concrete - level concrete - , you have to use an underlayment containing a DPM layer and sound-insulation layer, nowadays combi-products (very handy!).
Thank you. I haven't bought the flooring yet as I'm waiting to until I know the best option to go for.
we just laid a Junckers floor which has a weird metal clip system so that it go over a concrete floor (after you have put down all the right underlay). It was expensive, but looks wonderful.
Had my oak floor laid for about 3 months now - really pleased. Combilay and then glued all round. If large rooms then leave a decent expansion gap. It moved quite a bit while we were painting the walls and woodwork due to the moisture.
Two rules of thumb comes in mind:
All wet work should be finished before installing the wood.
Expansion gaps: 3mm per meter width of the room, minimum 10mm
