I am going through quotations for a single storey rear extension and some of the first figures have been well over my expectations. I now have concerns whether the quotes are just over the top or I am being deluded about my expectations...
I don't expect people to breakdown costs for me, just want to share some ballpark figures below and see what others think. Every project has its own merits, kitchens, bathrooms and other aspects of the build can increase costs drastically. So I am only focusing on the building cost which at the moment seems way too high. e.g putting the shell and primary finishes together, excavation, foundations, shell blockwork, plasterboards/skim, roof construction/insulation, then electrics/plumbing.
The place is a 3 bed semi off the inner belt of the M25, zone 6 in London. As a rule of the thumb I have allowed around £2000/m2 for good quality finish, I presume these figures to be inclusive of labour and completed interior plus VAT on top.
As an example, a neighbour in the area carried out a similar extension of 3.6m, mid-range quality with utility/WC area for around £60k+, the figure includes VAT and supplied materials. I cannot tell if it was on the lower end though.
Adding my extension spec below (pic attached),
The total footprint of the extension part is approximately 22 m2 (18 m2 encroached space) with the old galley kitchen split to WC/Utility around 5 m2.
The bifolds, skylights, kitchen and appliances, tiles, paving, bathroom sanitary, light fixings etc are separate costs on my end.
I estimated figures would not exceed £50k inclusive of VAT for up to the primary finish and hopefully decoration for this extension size. I allowed for a good above average kitchen, so the total budget to be around £75k + contingency.
Am I deluded or the quotes are insane?
Note quotes exclude own costs above and not a full list of every spec, include supply and fitting for two small PVC windows and fitting of supplied skylights. Added some of the highest figures below the quotes.
Quote#1:
Total £55k+VAT (£66k)
Shell £29,000 + VAT
this figure includes foundations, blockwork, roof, plasterboard and skimming, K-render
Electrics extension+utility/WC £3,000
Plumbing £4,500
UFH £1,800
Decoration £3,500
Carpentry £3,000 (no idea what that is...skirting boards and architraves?!)
Quote #2 :
Total 63k+VAT (£75k)
£30,000 + VAT shell with plasterboard finish, skim and joinery, K-render, no decorations
Electrics extension+utility/WC £4,000
Above ground drainage/Hot&Cold water £2,600
UFH £3,000
Interior Tiling £2,300
Kitchen fitting £2,300
Thanks for reading!
- The shell is 4.0m (D)x 5.0m (L) with low pitched roof, interlocked tiles
- two large skylights (2.0m x 1.0m openings)
- The rear is mostly bifolds across the length for about 4m.
- The old galley kitchen to be split into a small WC and Utility area.
- To this you can add the removal of an old rear chimney stack and demolition precast garage, UFH and patio slabs.
Quote#1:
Shell £29,000 + VAT
Plumbing £4,500
UFH £1,800
Decoration £3,500
Quote #2 :
UFH £3,000
Thanks for reading!
