I have quite a few minor issues with my roof and have finally got around to trying to get these fixed.
Briefly these are:
Two cracked concrete tiles.
Ill fitting bargeboards on one side, there is a gap of varying size from bottom to top under the cement boards.
Front and back fascia boards are too short (height wise) so the end tiles are higher than the rest, also in one corner the first five or so tiles are balanced on plastic spacers of decreasing size.
At the front the felt/membrane is trapped in places behind the fascia board.
The aluminium gutters have some brackets and screws missing.
Apart from the cracked tiles all these issues were the work of the people who replaced the fascias/soffits 15 years ago. I only noticed last year.
I have a quote for the following:
Take down gutter and fascia board at front and back. Replace with fascia of the correct height.
Replace first strip of felt if the existing is unusable from being trapped behind fascia.
Refit gutter and replace missing brackets/screws.
Fix 2" beading to cover gap on incorrectly fitting barge board.
Replace the broken tiles.
The estimate for this is £950.00
It seems steep to me, what do you think? The alternative is to do nothing until it becomes a real problem. I have no leaks I know about.
Not sure what to do.
Thanks,
Adey
Briefly these are:
Thanks,
Adey
