    Dismiss Notice
reassurance required… painting interior doors?
Discussion in 'Decorating and Painting' started by JanK, 18 Dec 2013.
  1. JanK
    JanK
    26 Jul 2013
    122
    Thanks Received:
    Surrey
    Country:
    hello. i'm going to be painting the internal doors here. the ones i have are varnished wood with about 15 glass panels 3x5.
    i want to get rid of the wood look and paint them white.
    i was thinking that i need to sand off the varnish, prime, and then paint with satin.
    is that right?
    also how much sanding will i need to do? will i need to remove all the varnish?
  2. Burnerman
    Burnerman
    7 Feb 2008
    21,698
    Thanks Received:
    4,194
    Northumberland
    Country:
    That sounds about right - the varnish needs to be completely flat and stable....no flaking areas etc.
    If you are unsure about the stability of the varnish, have a look at the Zinsser primer range - there will be something suitable there.
    John :)
  3. Sponsored Links
  4. Robbie uk
    Robbie uk
    9 Apr 2007
    2,059
    Thanks Received:
    267
    Cheshire
    Country:
    The varnish doesnt need to come off completely, but you need to sand it enough to take the shine off and make it look flat. A good dusting off and a sugar soap wont do it any harm.
  5. JanK
    JanK
    26 Jul 2013
    122
    Thanks Received:
    Surrey
    Country:
    Ah, excellent.
    Another question I have. I have just seen a very old forum string where someone said that the areas that they sandpapered and put the satin straight over did not chip, whereas the areas that they used undercoat followed by satin did chip.
    Is it better to use undercoat on the doors or not?
  6. Sponsored Links
  7. Robbie uk
    Robbie uk
    9 Apr 2007
    2,059
    Thanks Received:
    267
    Cheshire
    Country:
    Most paint will only chip off previously stained wood if its not been sanded properly. Its all about providing a key for the next coat. I personally would use an undercoat, but an oil based one, then follow up with the top coats of your chosen finish.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
