Reboarding "new" ceilings
27 Oct 2013
Hi all,
Quick one, some of you may know I'm doing most of the work on my loft conversion on my bungalow.
I have taken down all the ceilings and have new floor/ceiling structure ready to plasterboard.
Question is should I be knocking off a bit of wall plaster so the ceiling boards sit 'into' the walls and then make good or doesn't it really matter?
I'm also doing it in 12.5 straight edge 2400 x 1200 in case it makes a difference.
Cheers.
I did that and it made it much easier to put the boards up although I could have hired a board lifter.
I used the same boards as you.
Slight change, my local TPs only has 1800 x 900 12.5mm in stock. Given my joists are on 450mm centers does it really matter apart from a couple more butt joints.
