Rebuild Single Garage Question
  • Thread starter Thread starter TKH
  • Start date Start date
TKH
6 May 2014
Middlesbrough
Hello,
I recently bought a late 60s house with no conservation restrictions on it or the area around it. It has a flat pack preformed concrete single garage that is literally falling apart in the back garden. So my plan is to demolish it and rebuild a new one however I need a little advice.
The original garage is simply built on a concrete slab. If I was to remove the original garage and rebuild a single skin brick garage under 15 meters squared with a single pitch roof that is under 2.5m on the original slab, am I correct in thinking I would not require planning or building reg approval?
Then my next question is the same as above however if I remove the original slab and cast a bigger one ( again like the original no footings ) and build a 19 square meter garage am I correct in thinking again I would not require planning or building reg approval?
Many Thanks
Thank you for your speedy reply Freddymercurystwin. I had a good read of the governments planning portal. It appears to show I do not require planning permissions or building regs compliance. But I may be reading it wrong?
Don't know! Are you reading it wrong? Nothing you have said suggests it could not be built under PD. It may be worth checking with your Local Authority to make sure your house retains its PD rights.
  • Thanks
Reactions: TKH
With the 2nd option, you will need to make your roof "non-combustable" if the building is within 1m of the boundary as it is 15-30m2.
Don't forget, all glazing / electrics / heating should technically still conform to BR and be installed by qualified or competant persons where required.
