Recessed Electric Meter Cupboard - Insulation ?
5 Jul 2006
Kent
My electric meter cupboard is recessed into the cavity wall, almost touching the the outer wall, so there isn't much between it and the cold.
As the meter cupboard is all metal, I believe it forms quite a thermal bridge in the wall.
It measures 86 * 46 cm.
I was wondering if it was worth fitting a "celotex sandwich" door - basically two layers of mdf with celotex in the middle to fill the hole ?
The rest of the house is filled with cavity wall insulation.
My other option was just to fit an 18mm mdf door and not worry about it !
23 Oct 2007
Glasgow
Well seeing as nobody else has answered i'll have a go.
First off, for insulating any gaps around and behind the CU you might be better asking in the building forum, except to say that electrical power cables, with a few exceptions, should not be surrounded by thermal insulation unless this was taken into account when the cables were installed.
As far as fitting an insulated door, I can't see a problem as long as the meter cupboard is dry. A bit of cold won't do the breakers any harm but if it's damp in there the metal enclosure will start to rust. If there are gaps around the CU and at the back they could be filled with foam/celotex but check thats ok with it being a cavity wall as i'm not sure :confused:
