I've been meaning to buy a reciprocating saw for a while now, for some jobs in the garden (cutting through some thick branches) and also for other DIY, including rough cutting through this 30mm copper waste pipe.
I've found a pretty cheap saw here:
https://www.screwfix.com/p/titan-ttb533rsp-750w-reciprocating-saw-240v/17639
and wondered whether it would be up to the job. The specs say
"Stroke length: 25mm. Max. cut in wood 115mm, steel 15mm."
Presumably that is the maximum depth in solid material, so would I be OK (with the correct blade) to use it to cut the waste pipe?
Obviously the saw is pretty basic. So what kind of DIY jobs would be out of its reach?
Any thoughts would be much appreciated.
