Hi, I've just bought some reclaimed Junckers beech flooring, cracking stuff, 129mm wide boards x 22mm thick, T+G all four sides. I need to re-cut some of the T+Gs on the ends as the guy I bought the floor off had to cut some of the longer boards for transport. Would appreciate advice on the simplest way to do this - do I have to get a router table, or is there some way of making a jig and doing the job with a hand-router? Bear in mind that I only need to make short cuts across the boards - the T+Gs on the long sides are all intact. It's been suggested to me that I could just re-cut the ends perfectly square and use a biscuit jointer?
If it has to be a router, what sort of bits have people used for this kind of work? Looks like there are two options, one piece T+G cutters or separate bits for tongue and groove. I'm a reasonable DIY carpenter, but haven't much experience on the router.
Any advice gratefully received, TIA
Nick
Nick
