Recommend 0.1 bar modern basin mixer tap, ( mono mixer single lever) ??
24 Jul 2015
Hi
I have 0.1 bar hot water pressure. I am aware that many modern taps tend to operate effeciently only with minimum 0.2 bar. I am also aware from feedback that cartridge taps that state 0.1 may also operate at a dribble.
Can anyone recommend a modern looking tap ( with one lever at the top ) that HOT water works reasonably at 0.1 bar.
Otherwise I will have to be resigned to chose a mixer with 2 tap heads, of which there is a sufficient choice.
Thanks for your suggestion wizza. Have you used or installed this tap yourself?
Does the highlight of the hot mean that the cold is at a different pressure?
If the hot and cold are not at the same pressure, any mixer tap will be useless.
I know what you mean regarding a mixer shower with uneven pressure...it's either too hot or too cold.I have an ikea edsvic kitchen mixer tap and the cold on mains works fine but the hot is slow.
Don't most basin mixers actually mix outside the tap ?
