I am sure all plumbers and heating engineers have their favourites but can anyone recommend a condensing boiler as a replacement to an Ideal Mexico FF100 currently installed in our Village Hall?
As I understand it needs to conform to the following:-
1) Be a condensing boiler due to change in Regs
2) Ideally needs to be wall hung to gain space in the current location.
3) Needs to be A Rated
4) Have an output of at least 36Kw (125,000 btu) as the current boiler appears to be undersized (unless you are going to tell me that A Rated boilers are much more efficient and therefore I can get away with a lower rating).
5) As it is replacing a boiler on an old vented system I am told it needs to have a stainless steel heat exchanger in order not to experience corrosion with aluminium ones.
6) Capable of working as an unvented boiler if that is the way the system is redesigned.
Any help and advice would be greatfully received as there appear to be a myriad of different makes and types of boiler out there.
Fozzie
Fozzie
