Recommendation for drain cover
2 Oct 2010
Surrey
I'm trying to identify a suitable drain cover to replace the half-broken piece of concrete that's doing a bad job of holding the drain pipe in place - see photo. From the measurements I've taken it looks like the inner diameter of the outer ring is approx 160mm.
The drain pipe is only friction fit so I can remove it to fit a cover. Just need to find a suitable item. Access is somewhat awkward, being in at the end of a 20cm gap between my balcony (~ 1m long) & building wall, so something i can slide fit round the drain pipe would help in fitting. Can anyone point me in the right direction ?
Matt
Search Google for round drain cover , thousands of options
If you get a plastic one you can trim it so you can fit it easily
Yeah, been doing that - as you say thousands of options. hence the ask.
Given the variable quality of internet sourced items I like to get specific recommendations wherever possible. hopefully minimises the accumulation of things that don't work too.
