hi everyone
i'd be grateful for your recommendations on oil fired condensing boilers and pipework arrangement to facilitate HWS priority control. the application is a dwelling where the boiler output is based on space heating load at about 18kW. the existing heating scheme is an open vented dual system and comprises a solid fuel stove and oil boiler. the proposed piping configuration is S-plan with three zones: 2 HTG and 1 HWS. the boiler room is isolated from the house and includes a conventional flue.
the question on piping layout concerns priority hot water control for the oil boiler. Q.1 is a 3 port divert valve be required to achieve HWS priority control
and Q.2 if a 3 port diverter valve is necessary, can the heating line of the 3 port valve be hooked up to the solid fuel in parallel, before two zoned sub circuits?
some desirable boiler features include:
fully modulating
weather compensation
how water priority
quite operation
reliability and efficiency are key factors as well.
any help/advice would be greatly appreciated
thanks for reading
best regards
s
fully modulating
how water priority
quite operation
thanks for reading
best regards
s
