Recommendations for a Zone 1, extractor fan.
3 Jun 2024
As it says really.
The impossible I know, but thought I would ask any way.
I need to get a Zone 1 extractor fan. (wall mount)
100mm
4" blades.
Backdraft feature, built in, not anything you have to stick in the pipe.
High (as possible air intake 74?? or what ever it is)
Fan grill showing, not the kind with a decorative plate on the front, as it gives a ninety-degree angle to suck the air in.
We have a solid pipe through the wall, new build, of 20 years ago.
We had a new en-suite, and they put a cheap fan in it, and we are getting condensation runs/stains on the paintwork, and you can here the thing in the livivng room from upstairs.
So, what have you got? I have looked at so many, and the numbers are daunting trying to compare them to each other.
Our budget is up to £100. My installer said to look at Expelair or Vent axia.
Cheers for any replies.
Whilst there are some fans that are ok for zone 1 my recommendation is 12v.
As for the existing fan do you have sufficient air flow under the door? 6 - 10mm is necessary
This is a really good point.
An adequate gap is needed under the door so the fan can suck sufficient air from outside the room to replace the air it extracts.
We had a fan fitted in our en-suite as part of a load of renovations. I argued with Mrs S It needed the door truncating. She didn't want that, complaining it would be "chilly". The company made no mention of needing a gap. It failed prematurely. I argued again with Mrs S that it needed adequate gappage.
Anyhow, the company replaced it. Again with no mention of a gap needed under the door.
And that failed too.
So I replaced it with a different brand. But not until a goodly chunk of door was sliced off the bottom.
So far, so good.
PS
There is a formula somewhere to calculate how big the gap should be, depending on how wide the door is and how big the fan is.
