reducing size of spindles
10 Feb 2008
Sheffield
hi
i am installing some spindles which need reducing in size as they go up the stairs as they finish under the ceiling. I have chosen some that are fairly plain to avoid problems with the profiles but what is the best way to reduce them in size ?
i assume you mean cut to length!!!!
just use a mitre saw and remember the offcut from second short spindle will probably be long enough to go up in the "V" at the top
