    Dismiss Notice
Refinishing a veneer dining table
Discussion in 'Wood / Woodwork / Carpentry' started by ag359, 25 May 2013.
  1. ag359
    ag359
    7 Aug 2012
    7
    Thanks Received:
    London
    Country:
    I have a veneer dining table the surface of which has seen better days, and I'd like to give it a bit of a spruce up. In particular there are quite a few white marks, and the middle section (which obviously wasn't used much by the previous owner) is a completely different colour. I've attached a couple of pictures so you can see what I mean.
    I should say that I don't need or want it to look absolutely perfect, just a bit better than it does at the moment!
    Can anybody offer some advice on how to go about this? I'm particularly worried about the fact that it's veneer, so sanding may not be an option. Google isn't helping me much!
    Any advice appreciated... :D
    [/img]
  2. Sponsored Links
  3. foxhole
    foxhole
    14 Mar 2006
    16,202
    Thanks Received:
    1,811
    Kent
    Country:
    When posting click on show my pics and select to add to post.
    You can use a hot iron over tissue on white marks, it evapourates the trapped mositure and the tissue soaks it up anmd prevents burning, keep iron moving.
    Fine wire wool overthe top clean off with white spirit [don't clean with water].Then apply a coat or two of danish oil or top oil.
  4. ag359
    ag359
    7 Aug 2012
    7
    Thanks Received:
    London
    Country:
    Thanks foxhole. Pictures now added, in case that changes your advice?
  5. foxhole
    foxhole
    14 Mar 2006
    16,202
    Thanks Received:
    1,811
    Kent
    Country:
    Go easy on the clean, veneer look worn very thin.
  6. ag359
    ag359
    7 Aug 2012
    7
    Thanks Received:
    London
    Country:
    ok will do. Stupid question but do you mean wire wool first and then white spirit, or do you mean apply the white spirit with wire wool?
    What about using a specialist finish stripper?
  7. foxhole
    foxhole
    14 Mar 2006
    16,202
    Thanks Received:
    1,811
    Kent
    Country:
    Dampen wire wool with white spirit and also use it to clean off wire fragments.
    Does not look like you have any finish left to strip.
  8. foxhole
    foxhole
    14 Mar 2006
    16,202
    Thanks Received:
    1,811
    Kent
    Country:
    duplicate
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
