Hi, some advice needed please
I bought a solid pine bed v cheaply second hand, in the process of refinishing it for ourt little boy. It was originally 'orange pine' with a v high shine varnish finish, I want to partially repaint in cream but leave the upright posts in bare wood. I've sanded it down, not enough to remove all the varnish just to key it up, and am priming the bits to paint. My question is about the posts which I plan to have as bare wood. They were super glossy, so I managed to reduce the shine just by gently abrading with a sanding block, worked quite well (although there are some scratch marks visible in places which I guess means I need to go over with a finer sanding block?)
I'm unsure how to treat the wood parts. I like wax finish but as there's still some varnish on, I assume his won't work? Do I need to just revarnish in satin/matt varnish, or is there a product that will enhance the colour and finish a bit that will work on an already varnished surface? Thanks v much
