Reg 526.8, multiwire, fine wire and very fine wire
  • Thread starter Thread starter holmslaw
  • Start date Start date
These are different contructions of a single conductor for the same cross sectional area.
Single as in standard twin and earth
Multiwire as in the old 7/029 fixed cable
Fine as in between 7 and 21 wires in a fexible conductor not continuously being flexed
Very fine as 21 to as many as 100 or more wires per conductor in a very flexible cable such as the cables to lift carriages and moving machinerysuch as cranes.
The actual numbers quoted may not be accurate if there is a formal defination but the principle is correct
The regulation in plan language means use ferrules
as shown below crimp pliers. Or here
although you can solder it seems with stranded cable where a normal clamp type connection is unlikely to make a good connection.
