regular f22 on turbomax plus
21 Nov 2016
Hello,
I'm very puzzled with an error I have on my turbomax plus 824E,
I would really appreciate if you could share your thoughts.
I have an intermittent F22 error.
The pressure is around 1.4bar.
The pump seems to be rotating ok: it's vibrating, rotating but the pump itself is always very very hot.
I have replaced all NTCs and the pump capacitor but it didn't change anything.
the secondary heat exchanger is clean.
when purging the boiler, the water is very clean.
I would really appreciate if one of you has a clue ?
Many thanks
Is this the case with the flexicoms too?, didn't know f22 was anything other than temp / blockage.
U need a gas engineer who knows this model as its a gas problem
a gas engineer will come first (100£), say some parts needs to be changed (min 100£), but he doesn't have that part in his truck, so he needs to come back (100£) and spend an hour changing it (100£).
So I'm trying to fix it myself first, I won't touch anything to do with the burner and gas pipe, but the rest is plumbing.
except that I'm a bit stuck, hence looking for your experienced feedback
Sorry Bill, was for bunnyman. Flexicoms are cheap vailants
Get a different engineer.
Isn't the flow temp sensor inside the combustion chamber?
Which a DIYer should not be opening?
Tony
Tony
I dont think it is really in a condensing boiler, more inside the air chamber if anything imho
bill1206 looks like you need a gas engineer ,you've already eliminated one component but the other will cost you a bit and you can't fit it yourself , as if your going to listen :rolleyes:
The flow sensor is on the right of the main heat exchanger.
That is inside the sealed outer combustion chamber which is the room sealing component and what should not really be opened by a DIYer.
I know, pedantic i know but that is not really a combustion chamber as that would be behind the burner seal. Its an airbox.
Turbomax is a fan assisted SE type boiler and not a premix , removal of the inner case will breech the combustion chamber...if you're not sure of the working principles of these boilers then refrain from giving advice.
For that matter the inner burner box is not sealed.
The room sealing is the outer box.
Therefore the outer box integrity should not be breached by a DIYer. [ or breeched either ]
