I would like to rehang the door in my bathroom. I want it to continue to swing into the bathroom, but on the other side.
what's the best way to go about this? i figure, I could just rotate the door 180 degrees, but I guess I run the risk the door is asymmetric in some way and no longer fits. however, if it did, it would have the advantage that I wouldn't need to move the hinges to the opposite side of the door and make good on the old hinge recesses in the door. So, is this a common way to do this? how likely is the door not going to fit if rotated.
I guess the other route is to not rotate the door and move the hinges. that might be easier.
I know if I rotate the door a may have to move the handle and lock as well as they are unlikely to be vertically centred.
