Reinforcing a wood garage door against thieves.
9 Aug 2006
Lancashire
Our up-and-over garage door is made of wood but is pretty heavy and good quality. I have reinforced the top of the frame with steel and fitted a strong bolt to prevent the top from being pushed in, while the bottom corners have bolts that butt against the frame to prevent the bottom from being pulled outwards. I reckon now that trying to break the frame would need a vehicle and would make a lot of noise so my next concern is to make it harder to smash though the actual panels, which are only plywood.
The best and lightest way I can think of would be to get two alloy plates cut and glue and screw them to the insides of the panels so as to form a solid additional layer with the plywood.
What glue would you recommend? I'm thinking some kind of epoxy that will set by chemical action since a water-based glue won't dry and could warp the door. Alternatively a second layer of ply, perhaps marine grade, screwed and glued with PVA would give additional strength and slow down a thief.
Just a thought as its an up and over door, mate - they are designed to work only with their specified weight so don't overdo the add on material.....alloy plates could be best but of course the toe rag wouldn't know they were there until they had had a go to get in.
John :)
Thanks. Builder here on site has suggested a sheet of alloy screwed to the inner framework, not glued to the panels because scrotes could still kick the entire panel out. The alloy sheet attached to the inner framework would reinforce the entire door and the latches and form a secondary barrier if they succeeded in kicking through a panel.
If I filled the space between the panel and the inner alloy layer with expanding foam it would give even greater strength and some insulation.
