relight baxi wm40 boiler
8. Hold in the green ON/OFF button on the gas control valve.
9. Press in the igniter button and release. Repeat until the pilot lights. Hold in the green ON/OFF button for approximately 15 seconds and then release. The pilot should then stay alight. If the pilot fails to remain alight then repeat the procedure from 8. The flame should be without a yellow tip and should extend past the pilot shroud by approximately 12mm (1/2in).
10. Turn on the mains electricity supply.
11. Operate the burner by turning the thermostat knob to the no. 6 setting - FULLY CLOCKWISE.
