Relighting Puma 100e
8 Feb 2004
Wolverhampton
Can anyone help relight this one for a lady friend of mine.
I have been told there is no valve to push in or an igniter,
Thanks :D
"e" means no buttons.
How far does it get?
So often it's the main pcb. If you need a new one, I could see what I've got...
E = electronic!
There's nowt to relight.
Electronic ignition should light it up each time it starts.
Puma 100E , has automatic electronic ignition , no pilot light , which can be manually operated.
What is happening is both heating and DHW is not working. Does not fire when hot tap is turned on.
Anything I can try?
If you look at the PCB when a hot tap is opened, does a red light come on? Anything else happen after that? Fan noise? pump noise?
Does switching on the CH (to constant) have any effect at all?
also have a look at the main PCB (on the front behind all the knobs) on the top left hand corner, if you see smoke damage it needs a new one, they are buggers for burning out
also have a look at the main PCB (on the front behind all the knobs) on the top left hand corner, if you see smoke damage it needs a new one, they are b*****r for burning out
I was coming to that next - breaking the bad news gently :(
Thanks lads for the replies. :D
I haven't looked at it and shall leave it for an engineer to sort out.
Check the basics first, electric fuse, system water pressure etc. if you haven't already.
I fink you're enough of an engineer to change a pcb!
Resolder it for her even!
well you are a more compassionate man than me croydon :lol: :lol:
pop a new one in bahco they are POP to change
i have a potty 100e
these may help (my old potty 100e pcb)
below the orange label is a fuse (marked fuse funnily enough)
they also seem to fry themselves (see white wire)
its mounted on the back of where the two grey temp knobs are on a drop down "shelf"
as has been said, doddle to change
