Reline / Repair lead lined Victorian rain gutter.
22 Feb 2009
Manchester
The wooden box gutter requires relining with lead sheet, the gutter is across two Victorian terrace houses, with one down pipe made of cast iron. The box / wood may require some repair, however tips on the job in hand would help particularly to the re-lining of the lead sheet to the gutter. length of gutter is approx 12 yards.
Thanks,
Lewis55
Hi.I would like to assist but am unsure of the exact orientation of the gutter, They vary greatly from building to building, some at the base of two pitches, others at pitch / parapet. Also through the building via loft space. The material, method and skill level will differ according to the situation. If you are able to post a couple of images of proposal, help will be at hand.
As JL has said it would be easyier if you could post some photo's as there are too many variants to what this might be.
Cheers
Dave
