I am a homeowner and have a Remeha Avanta boiler plus which loose pressure on a very cold / freezing night. It does not always go to zero but low enough to stop the boiler starting until additional water is added to raise the pressure.
I experience this problem last winter and focused on leaks around the house and followed directions from the engineer. The boiler has worked successfully since last winter, the pressure was ok yesterday, but on our first cold night the pressure has dropped.
When looking at the boiler to top up the pressure there was drips of water around the flow pipe” nipple “from the boiler
Any direction would be appreciated to determine a boiler issue or a potential leak on the pipes which is not obvious
