I am in the process of creating a new chimney breast for large hole in the wall fire. I have removed old gas fire and surround and taken down the old breeze block chimney breast that was built out to the same depth as the gather. I now want to remove the starter blocks and the gather so that everything is back to the cavity wall then block up the old opening so it becomes a flat wall I can fix my new fire back to and then install the balanced flue straight out through the old precast flue. My question is will i need to support this old flue while i block it up? Will i be best putting a lintel in first and blocking it up after that? House was built in 1995 if that helps as to what sort of flue it could be.
Any help greatly appreciated!
