Removal of two structural walls and installing RSJ's
7 Jan 2016
Hi All,
I am in the process of buying a house and the current layout of the ground floor has the living room and kitchen running parallel to each other and open at both ends (see floorplan attached).
However, I am keen to remove two structural walls that divide both rooms to open the whole of the rear of the house up. One wall is circa 6.5m and the other is circa 4m. The shorter wall currently contains a chimney stack so the stack above will need to be supported by the beam. I appreciate a structural engineer will be needed along with building reg sign off etc and decorative work etc.
Ideally I would want the room to be one big open area without any pillars but fear the point where both walls meet (circled) will need a pillar to support them and perhaps the 6.5m reach is too great for a single beam without a support midway.
I would be very grateful if I can get some advice whether this is possible and get an idea on ball park costs.
Many thanks
George
Anything is possible. However, the beam across the (presumably original rear of the property) maybe quite deep and is more than likely will need to be a "goalpost" frame, to provide lateral stability across the width of the building. As "noseall" says, floor joist spans of the first floor and walls above are ideally needed (job for the weekend). Picking up the chimney breast from first floor and above will need some good needling, strongboys, temporary works.
