Remove old olive from radiator fitting
You must have another tank that feeds the central heating system ,unless it's pressurised.
What did you do when draining heating system to work on the radiator ,what did you turn off ?
Hi, just turned off the mains water and drained down the damaged pipe with a hose as it wasn’t planned.
Turned the mains water back on which is giving some hot water now but no CH yet, stopped the flow to the header tank as a temp measure. No tank in the loft
Have you ever drained your central heating system in the past ?
What boiler heats your central heating system ?
Not myself no, this all started with a leaking rad (not on any connections)
My boiler is a very old Ideal standard lx ff
Not sure how to check if they have filled back up sorry, I bled whilst emptying and draining
If you open a radiators air bleed valve ,air may come out first followed by a stream of water.
If no water comes out of ALL the radiators ,the system hasn't filled up.
Fitted the new isolation valve but that leaks from the bit where the smaller pipe joins the larger one. Have I missed something?
Not sure what you mean. One end of the service valve ( isolator ) connects to the tank inlet, the other end is a compression fitting onto a piece of copper pipe. Is it the compression fitting that leaks,where the nut tightens onto the valve ?
If so ,did you remove the original nut and olive ,or leave them in place and just connected the new valve to them ? Tightening the nut a bit more may stop the leak if you re used the original nut and olive.
Sorted the leak thanks, it was a faulty valve.
The header tank seems to be filling up now, I have the boiler on but the rads are not hot yet, the pipes near the tank are hot, does it take a while to fill the whole system back up?
