Remove Tap cartridge
5 Jan 2010
Norfolk
Remove Tap cartridge.
Out Kitchen Hot tap requires the cartridge replacing Problem it's sized no mater how much I tried unable to release it,
Would applying heat from gas gun or Electric heat gun help or is there another solution to this ??
The Cold undid no problem.
Unless you are particularly attached to the tap, it may be time to consider a new one!
Sometimes, the effort outweighs the costs :)
...otherwise, you could try soaking the edge around the cartridge in something like Cillit Bang, Lime and Grime! ;)
