Hi everyone,
I've got a problem with a Triton Martinique shower.... where the low pressure light is always on.
The shower's worked fine for 3 years, this problem has only just started a few days ago.
The general water pressure seems fine to me, same as it's always been.
The shower manual suggests that the inlet pipe is blocked, so I've been trying to remove the fittings so I can clean/unblock whatever gunge might be in there.
Here's a pic of the shower + fittings
http://ibb.co/eQHGBv
I've already tried (switched the shower unit off at the fuse box, turned the water off, taken the front cover off), but that's as far as I could get.
I obviously need to remove the plastic fitting from the copper inlet pipe...
Does it require a special tool? Or is there a certain knack?
I've put the cover back on for now, but let me know if you need a photo of the inside....
Also bear in mind that I also need to use the same fittings again....
Thanks!
Thanks!
