hi, earlier i had to remove my old electric shower because the misses wants a manual mixer shower in.
i turned off CU and disconnect live from fuse. snipped L n N as far back as i could.Left the earth connected(should i cut this back too?)
left fuse in but switched off(should i remove fuse or is it ok like this?)
disconnected cable from shower and switch and cut back cable.
is this ok?
just unsure of removing earth from CU and fuse?
also what is the best way of covering up the old switch outside bathrooom
just remove back box and plaster?
cheers
mark
is this ok?
cheers
mark
