I have a freestanding gas cooker which I wish to disconnect. I will no longer require a gas appliance so I need to terminate the supply to this point.
The cooker is currently connected to a flexible hose which is then connected to a short length (approx 20cm) of 15mm copper pipe. At the end of this pipe is tap/valve with a 1/4" square nut and finally the larger gas pipe leading into the floor.
I have been advised by a kitchen fitter that, as the householder, I am allowed to terminate the supply to the appliance as long as I do not connect a new appliance. He said that closing this valve and putting in a 'bung' to the end of the pipe was all that is required.
Is this advice correct and what form would the 'bumg' be?
Would a simple 15mm end-cap with rubber seal do the job?
