removing cast iron pipe
18 Feb 2006
Birmingham
Hi
I need to remove a cast iron soil pipe. I have dug the ground to where itmeets the clay pipe, which is wider in diameter and seems to have some sort of cement around it.
b21playa said:
al-yeti said:
need to move WC and best way is to get rid of old cast iron pipe
Having a laugh right.
Just cut the pipe and re-position a new branch.
You damage the underground Clay pipe and you'll be digging all the way back to the chamber :shock:
I was advised last time on here to remove it all
what about if i cut the cast iron underground just before the clay with a grinder and use a fernco coupler (the one with jubilee clips) to attach the bit of CI to new plastic?
It wouldn't be my advise to remove it all.
For starters what does building control say about it, external castiron pipes and fittings are a requirement on some properties and Councils.
Back to the problem Yes a Fernco coupling would be better than damaging the undergroud drain
wil the coupling be fine underground, set in concrete?
If its below ground buy an Timesaver cast iron to plastic adaptor socket
Well I'd expext to remove it all! The cement that's used shouldn't be very strong. Over the years the pipe will have moved and cracked it. All I've seen have been very obviously loose enough to wiggle the pipe up and out.
thats what i was told before
If they used the right stuff Chris its like neat cement and as hard as a rock.
I would defy anyone to get it out without breaking the collar.
Just type Timesaver castiron pipe into Google
Hi.
Just like the OP I too have recently been advised to replace the soil stack. Mine is internal cast iron but is accessible behind panelling inside the house.
Reason given was because its hard to cut cast iron stack below floor board level to fit new bath waste (current waste not enough fall).
I asked about cast iron to plastic couplings / adapters and was told they no good.
Can anyone link to any suitable products?
When I did it I left the last section of cast pipe & used a alla Wickes plastic to cast jointer fingumi....
1. Because it was a nice & easy solution ;)
2. To guard against errant wheel barrows full O' gawd knows what poleaxing it & having poo cascading all over the gaff...... Which ya all will agree Aint't Pretty :D
