Removing chimney breast in livingroom and bedroom
11 Sep 2014
Can any one tell me how i would go about removing chimney breast from my living room and bedroom so i can have more space in house please?
Do i need planning permission?
Can i do the work my self?
Do i have to inform the neighbours?
Do i need a building inspector to inspect the work at the start and the end?
How long would it take to complete?
How much would it take to employ a contractor to do the work?
Do i need to use acro props for the joists when removing chimney breast?
etc
Any help would be great. Thanks
I'd ask about planning, but I didn't get planning permission when I removed one of ours and noone has complained.
I did the work myself (plus girlfriend). It's not hard at all, if you're completely removing it.
If it's on a party wall, you're supposed to notify them 1month before you start. There's no agreement on their part though, it's just notification.
I already had a buildings notice, which included chimney removal. They didn't bother to inspect the chimney though, but I removed it completely, as opposed to leaving an upper section supported by some gallows bracket.
It took a whole weekend, for two stories worth of chimney. I got a roofing chap to take the bit that stuck out the top of the roof when they re-did the roof.
I don't think acro props are required. Where were you planning to use them?
You don't need planning permission, unless it's a listed building.
As above, it is DIYable.
Strictly, you should inform the neighbours as it is a PWA matter, but don't bother, unless you want to spend £££ on surveyor's fees.
You need to advise Building Control as replacing the floor in the gap is a structural matter.
Costs? Depends............
You may or may not need Acro's, as in some rare instances, floor joists are supported off the chimney, though this is not usual.
re: acros
Actually, yes. My place is 1900, and the floor is all suspended around the chimney. In later houses this might not be true.
As for a buildings notice, I pointed them at the floor I replaced and they didn't give a monkeys :(
