Removing handles from aluminium door?
5 Jun 2012
Somerset
I would like to replace the handles on my aluminium back door as they are worn and tatty.
I have removed the cover plate which is made by UNION and removed the lock but cannot see how the handles are secured, please see pictures.
Thanks for any replies.
I think this one should be a cover plate that is friction fitted. If you try prizing the aluminium plate away from the door it should reveal the steel frame beneath screwed to the door. The cover will slide off over the handle.
Just flick the handle cover plate off, its held on with black plastic lugs which you can see at the top and bottom, its these that are screwed into the door which in turn hold the handle on, before you prize the handle off make sure theres no hidden grub screws on the lever handle, i would imagine there is so when pulling on the handle it transfers the force onto the spindle instead otherwise you'd pull the handle off its black lugs all the time
Might be too late, but when i changed mine, Like Crank says above there was a grub screw on the base of the indoor lever. undid that, and the handle slides off the square bar that goes through to the outside handle. with them off the plates of the handles can be taken off the door
hope that helps
