    Dismiss Notice
Removing moss from garden path (and not killing grass)
Discussion in 'In the Garden' started by Gossamer, 11 Nov 2019.
Tags:
  1. Gossamer
    Gossamer
    2 Dec 2015
    369
    Thanks Received:
    15
    Country:
    As above - any ideas?
    Needs removal then some treatment so it doesn't immediately come back.
    Cheers.
  2. Sponsored Links
  3. ktuludays
    ktuludays
    10 Nov 2008
    574
    Thanks Received:
    90
    Lincolnshire
    Country:
    Pressure washer
  4. Gossamer
    Gossamer
    2 Dec 2015
    369
    Thanks Received:
    15
    Country:
    I assume it would blast it off with ease. Do you then treat with chemicals to stop it coming back?
  5. Notch7
    Notch7
    15 Sep 2017
    24,632
    Thanks Received:
    1,756
    S. Uplands
    Country:
    ive got the same issue as my fathers house -whats best pressure washer or moss killer
    and as Gossamer asks -should chemicals be used after washing
  6. lostinthelight
    lostinthelight
    11 Feb 2016
    3,088
    Thanks Received:
    593
    monmouthshire
    Country:
    • Like Like x 1
  7. Halitosis
    Halitosis
    7 Oct 2014
    235
    Thanks Received:
    37
    West Lothian
    Country:
    • Like Like x 1
  8. paulrockliffe
    paulrockliffe
    28 Aug 2014
    157
    Thanks Received:
    19
    Durham
    Country:
    Iron sulphate to kill moss. Don't pressure wash until it's dead or you'll fill the lawn with moss!
  9. Halitosis
    Halitosis
    7 Oct 2014
    235
    Thanks Received:
    37
    West Lothian
    Country:
    iron sulphate works on a lawn but doesn’t it stain paving?
  10. Sponsored Links
  11. scbk
    scbk
    22 Dec 2012
    896
    Thanks Received:
    168
    Ross-shire
    Country:
    Soda crystals, about £1 a bag in Tesco etc
  12. Matt42
    Matt42
    14 Sep 2010
    167
    Thanks Received:
    Hertfordshire
    Country:
    Pressure washers are too destructive. Sweeping in diluted wickes bricks and mortar cleaner works a treat for the initial cleanse but be wary of run off. And then just spray moss killer every now and again.
  13. Gossamer
    Gossamer
    2 Dec 2015
    369
    Thanks Received:
    15
    Country:
    Thanks all. FWIW I did the following:
    1. Brushed the moss off with a stiff brush. This got rid of perhaps 90% of it. Tried with a pressure washer but it didn't really do much (surprisingly).
    2. Pressure washed the path to clear the brushed moss away and generally clean it up.
    3. Put Jeyes cleaner at a 125L / 5000L ratio to (in theory) kill the remaining 10%.
    4. I'll periodically hit it with Jeyes to prevent regrowth (assuming the Jeyes works of course....).
  14. ed1178
    ed1178
    15 Dec 2010
    29
    Thanks Received:
    Yorkshire
    Country:
    Copper sulphate kills moss but not grass, and you need surprisingly little. It doesn't smell like a festival toilet either. A couple of tablespoons in a watering can once a quarter will prevent moss from regrowing.
    • Thanks Thanks x 1
  15. dal5band
    dal5band
    3 Mar 2005
    765
    Thanks Received:
    54
    Surrey
    Country:
    I used Patio Magic a year ago and it gradually cleared the black mould on the patio. I will re-apply once a year. Don't know what it contains but it seems to stay in the stone.
  16. StephenOak
    StephenOak
    27 Apr 2017
    369
    Thanks Received:
    55
    London / Kent
    Country:
    The (main?) active ingredient in Patio Magic is benzalkonium chloride. Patio Magic 'concentrate' is, IIRC, 7.5% and you dilute it 4:1 (or 9:1 for light growth).
    My front yard is north facing and in a poor state so it needs doing every year, so I bought 5L of 50% benzalkonium chloride which will last a long time
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
