removing mould and sealing
24 Apr 2008
UK, Wittering, West Sussex
i have a had a lieak inside a partition wall in a bathroom all ixed
Now just want to elimimant the mould and seal in
the wall had insulation wool in, which i have removed
it was a leak at the celing , and dripped down inside to the floor
The partition wall was made of 3 or 5 ply which had mould on the outside , very slightly in places
and i cut out a piece beneathe the cupboard
MY plan , and if any one else can help and suggest alternatives
i shall use some bleach on the ceiling plaster board an on the plywood to remove the existing mould -
BUT Thats just the outside , cant get inside -
BUT i suspect once dried out in a week , if we get good weather , it will just die off anyway
OR would i be better off with a product specific for mould from screwfix
then I need to seal it all in - so paint wise
somehting like - this
OR paint over with Zinsser B-I-N
What do you all think
Wash what you can reach.
Let it dry.
Zinnser BIN then paint.
I've painted over mould loads of times.
I just wash over with sugar soap or warm water with a splash of bleach.
Don't get worried about it. All easy enough.
Washing off is not really very effective anyway as it is stained.
thanks , excellent i got some BIN now - so once it has dried out - which is going to take a long while - we will wash down as suggested and then BIN it
Thanks again
Get summer fans in to move air.
Will speed up drying time.
But to answer. Yeah
got those going in the room and window wide open , then in evening i put a fan heater on just to get the rooma bit warmer, I alos have a small dehuidifier comming tonight - actually draw the water out , so we are not just recirculating it !!!!! - very very wet, in there , i suspect the wall has been soaked for weeks
I found a good white vinigar & bleach solution with 3/4 water & then a good anti mold paint is a good sealer & the walls i did 2 year ago are still good.
