Removing old floor tiles
23 Oct 2011
Berkshire
Morning all,
Moved into a house a while back which was built in the late 50's early 60's... Currently renovating the living and dining room, old carpet and laminate up and found these tiles stuck down with black adhesive (bitumen?)... The bitumen is only a very thin coating and only up to where the flooring ends I.e not under where the skirting was
The floor tiles are a few mm thick and the bitumen possible less (see pic)
I want to remove these because some of them are loose and turning up at the corners and I want to lay new laminate flooring However I've read a lot about this stuff being the DPM but only if it's very thick etc, but surely this isn't the case as it's very thin in my scenario
1. Is it safe to remove them? In terms of its not the DPM
2. How do I tell/find out if I have a DPM? I know it's different but I know I have a DPC, wasn't sure if it could be an indication!
3. The floor is pretty level but if I wanted to level it out using self levelling latex can I chuck this straight on top (after removing tiles)?
4. Anything I'm missing/other advice would be great!
Dean
They look like Thermoplastic (Marley) tiles very common for them to contain asbestos have a Google, lots on line about it.
As a rule not considered a risk in normal use and if small amount is broken fairly low danger from fibres as they are firmly bonded, but stripping a whole floor you should take advice from an expert.
The bitumen/adhesive layer under the tiles was frequently part of the DPM on a solid floor
