Hi, looking for a bit of advice!
I have a bathroom and the sink tap is very loose.
The previous owner has tiled all around the sink with no access or removeable sections. This is the same for the bath too so hope the plumbing is good
What is the best way to remove one tile clean.
I guess i needs to somehow rake out the grout and carefully pull it away. The tile is about 800mm high and 300mm wide and cut to fit so need to get it out clean
