Removing posts from metpost supports
16 Apr 2015
Hi all,
My garden is raised relative to the neighbour's with a block retaining wall. The fence separating the two gardens runs along the retaining wall with the posts going into concreted in met post holders in the wall itself.
Time has come to replace the 10 panel fence and the posts (want a taller, non rotten fence). Ideally I'd like to reuse the metpost supports. I know the trade doesn't like them but they are in the perfect position, don't wobble and I'd rather not get involved with my neighbour's retaining wall if I can help it.
As such, how to? They aren't the type with bolts to loosen. I've read that cutting flush, drilling them and chiselling them out is the only way, any other suggestions?
drill a hole through the centre of the post
bar through the post
jack the post out
or lever it out as
Edited
If you mean you just want to take out the wood, and leave the metposts in place, the posts will be wedged into those steel inner fins. I think you will need to brace your jack or fulcrum to press straight down onto the concrete If they are reluctant to come out without the supports, I think, as you say, you will need a big drill and a sharp chisel to break them up. The posts may have swollen since being fitted as they will be damper, and this will make them tight.
Thanks all, much appreciated.
I like the lever fulcrum idea, will give that a shot.
In the event that the metpost itself gets pulled out, do I just whack it back in with postcrete?
Cheers,
Donny
