Removing/reducing concrete block in garden
28 Jul 2008
Sussex
While I was digging over the back garden after removing the old lawn I hit a large concrete block. It was obviously for a sticking a clothes hanger in as there's a hole in the middle. The trouble is, it's about 40x40cm across and over 50cm deep, so a little over-engineered. I would like to remove it, or a least knock some off the top so I can overlay my new lawn.
It's going to need to brute force of some sort, what sort of violence would you recommend to deal with it?
A big sledge hammer...of if you have a largish capacity SDS drill, pop a hole in and then bash on in with a cold chisel.
John :)
I removed one of a simmilar size a few weeks ago, my brother had already tried attacking it with a large sledge hammer and pinch bar but barely made a mark in it.
I broke it up with a hydraulic jack hammer, but that's not much use if you don't own one! :oops:
I like the TNT idea (not the incompetent postal service after watching last night's Dispatches programme)! Actually something that could fracture the block into a couple of lumps would be quite helpful, but I wouldn't want to split my whole house in two!
I've dug down a bit further and still haven't got to anything less solid underneath. This block will probably weigh a 1/4 of a tonne, so being able to break it would help a lot in getting it out.
It's a pity I live in a quiet cul-de-sac a not one of the main roads which seem to be permanently getting dug up, as I could ask one of the workmen to pop in with his jack hammer.
I agree with the previous suggestion. I have removed two by drilling a small hole, getting a cold chisel firmly stuck with a lump hammer then hitting the cold chisel with a sledge hammer, it does eventually break a piece off.
