Are there any ways of removing tiles from a plasterboard wall without making too much mess?
Have smashed a couple and made a huge hole int he plasterboard - which is really soft.
Any suggestions?
I usually find it quicker and easier to remove the tiles & plasterboard as one then fit new plasterboard and tile straight onto that. By the time you have got the tiles off all the board fixings will be loose and it is quicker to put up new board than repair all the holes and once the paper surface is damaged the board looses its strength.
