Removing Wall for door
19 Jan 2008
Hi all hope your all well
Just a quick one really. I'm making a hole in a supporting wall for a 4ft wide door. The joists sit on the internal leaf of the wall the the external wall is just the wall above it.
Am i right in thinking a pair of acros inside supporting the ceiling would hold that side and a pair of strong bouyes on the outside to hold that side of things.
My next question am i right in think a standard concrete lintel will be fine for the application or do i need to up this to a rsj. I will be placing a lintel on the top of each leaf
Many Thanks for you help and any suggestions would be most appreciated
Your plan for supports sounds ok. Internally I would get a length of 6"x2" or something similar and lay it across the underside of the ceiling at right angles to the joists and just prop it with an acro either side.
Difficult to advise on lintel without more info. Doubt you would need an RSJ, probably fine with a 100x145 conc on each leaf. What's the construction? Cavity, 2 storey, brk/bwk, etc?
hi thanks for your reply
basicaly it is a an 1901 house. The wall is two leaf the door will be on the ground floor above this there is a bathroom and the bath is at that end of the room so potentail a bit of weigh. I was thinking about it last night i think i'm might go with a 6x3 rsj inside and concrete lintel on the outside. I'm also think it might be worth going with two needels though the wall but not sure i think the strongbouys and acros would be ok
Many Thanks
Daniel
don't bother with needling. the collateral damage outside - if any, can be repaired. strongboys will be more than, er, man enough.
1200mm ain't no hill o' beans.
as far as lintels go then what would you recommend the concrete lintels both sides or an rsj one side and concrete lintel the other
Many Thanks
Dan
For a 1200 wide door opening, any standard cavity lintel (Corus will even design you a Catnic one for free if you want, see Joe-90 for details* :)) will do, you don't need t make it complicated by using steel on one leaf and concrete on the other.
*as do other manufacturers, but Joe obviously hasn't discovered them yet
But will the BCO accept their specs?
Why wouldn't they?
After all, it's "only pushing a few buttons" on their design software, eh?
