renault laguna wiper problem
T
teddyb
Hi
Only since the snow and ice - one wiper blade has stopped. The central section where it joins the car goes round but the wiper arm stays still. The arm can be moved manually.
It seems as though it has come off its splines/cogs (or something). Is this likely? How do I get the arm functional again? The other blade works fine.
Could the ice have moved the arm off its position?
Any advice would be gratefully received - thanks,
teddyb
Sounds like either the splines on the shaft or on the arm itself have gone, you'll have to get it off and take a look. Try here: renaultforums.co.uk
Try simply tightening the nut that holds the arm on, unless the splines have sheared off this should work :D
