Render
10 Mar 2007
West Midlands
I am thinking of rendering a block built extenstion, can one you Pros tell what to do at dpc level.Do i have to finish above dpc level or not.Also do i use a waterproofer in the render mix
fix a bell bead at or slightly higher than the dpc.
use waterproofer in the top coat only. or if you want a bit of working time with the float coat, put waterproofer in the scratch coat too.
Thanks noseall,below the dpc if i did not want the brickwork showing is there something else i could cover that with ie pvc or the likes?
