Rendering after repointing internal wall
1 Mar 2016
I've posted this in the plastering/rendering forum too but it's a broader question so I'm reposting here.
I was planning to apply insulating render (the Bauwer Light system) to an internal wall. However, on removing the previous plaster, the brickwork is in bad shape.
There are a few patches where the mortar is pretty much gone from the internal layer of bricks (it's a solid Victorian brick wall). I think it's largely from when the wall settled slightly after a beam was put in on the ground floor. There's no ongoing movement 12 years later so I'm not too worried structurally. But I would like to repoint the brickwork before applying the render.
My question is: how soon after patch repointing can I render the wall? The render will be breathable if that makes a difference.
Read more: https://www.diynot.com/diy/threads/rendering-after-internal-repointing.508070/#ixzz5PYGGeZD6
If the render is breathable you can do it very soon, for an internal wall you can use sand and cement render and then plaster over it. Is the dpc alright?
