I have a few cracks on the horizontal face of a chimney stack that I would like to cure with a fresh layer or two of render. The existing isn't blown, but the cracks are letting in water. I was thinking of grinding a few cross pattern grooves in it before application of a fresh mix. Can anyone advise on mix ratios, whether to use lime, (the chimney is used for a real fire), and whether I should prime or just soak down the old render. A perfect looking finish is not required, just a weatherproof one! Here are a few snaps:
