My wife and I moved into a 1-bed end of terrace house about 6 months ago and I have been doing bits of DIY around the place trying to fix things or get rid of drafts. I noticed some time ago that the kitchen seems to be colder than the rest of the downstairs (it is basically one room but with a half-height partition between the two). I finally got fed up with it and decided to try and work out why. I took of the wood panels that cover the legs of the cupboards (like the fitted kitchen ones) and found a hole in the floor under the sink. It seems to be where the cold water enters the house (big black ABS type pipe that comes up).
View media item 30457
I don't know if it was shoddy building or why there is a draft there (I can certainly feel the air moving) and the hole is quite big and seems to be filled with paper cement bags, small cuts of mdf and random bits of metal!
View media item 30456View media item 30455View media item 30454
There doesn't seem to be any damp which is strange given that there is a draft and its quite deep into the floor.
I would like to fill the hole with something (cement, filler or something similar) but I'm not sure if this is advisable. Can anyone advise?
Many thanks,
Sebed
Many thanks,
Sebed
