Replace 13amp immersion spur switch
  • Thread starter Thread starter ih
  • Start date Start date
ih
4 Nov 2006
London
Hi
At the moment I have 13amp fused spur switch for my immersion heater.(it is mk switch with screw to get
to the 13 amp fuse it also has two metal prongs which slot into spur body)
1.I want to replace this with identical switch with neon and am looking at cb4827/3 and cm2369
the second does not mention DP do I assume all spur are dp and if above are compatible
thanking in advance
It would help if you could provide links to the products you have in mind!
So, I have tried to Google these. Both are DP.
  • Thanks
Reactions: ih
Use the MK K330-WHI part number - it's a direct replacement for the older version, available from Screwfix and B&Q and Toolstation for a good price.
It is a 13amp Double Pole Switched fuse-connection unit with flex outlet (White finish) ideal for such replacements.
  • Thanks
Reactions: ih
