I need to replace one of the timber posts that supports my porch roof. I think it's beyond repair due to the extent of the rotten wood I had to remove. Please see attached photos. There is a tenon & mortice joint at the top and the metal 'cup' at the bottom is fixed into the wall on a metal spike. So whilst I can easily remove the damaged post, I'm unsure how I would insert the new one due to both ends needing to be fixed in place.
I did get a quote for repair but I was let down a few times and then ghosted. He was going to cut the post and insert a new section, but I'm not sure how he would have done this, or how the post would have been structurally secure from a side impact.
Any advice or suggestions would be gratefully received - I have tried to get further quotes but no-one appears interested in the work. The only I did get was beyond my available budget.
A neigbour has replaced their timber posts with metal supports, removing the metal 'cups' in the process, so that's an option, but I would rather replace with wood if possible.
